1 - 8 of 8 Posts
I am in the process of finishing my rebuild and I've ran into a problem with the lift pump. I installed a compressor / power steering pump assembly and the assembly made the use of the standard lift pump location impossible. As you can see from the picture I've had to block off the original pump location. I realize an electric pump is an option, or a belt driven pump from IE the MITUSA pump. My question is does anyone have another solution, or has anyone ever seen a pump driven from the flywheel housing accessory drive?
Hello, looks great! I don't have a solution for the lift pump except electric. I was wanting to know where you got the air compressor power steering set up from? Do you have another?
Thanks, Ed
It should be pretty easy to find an electric pump that would work. Mount it as close to the tank as possible.
Discussion Starter · #4 ·
Thanks, Ed
The assembly was off a Bluebird bus with a 5.9l. I had to have the pump rebuilt with a lower pressure bypass to keep from blowing the seals out of my steering box. I don't have another one but if your patient you could score one on ebay fairly easy. The rebuild kit for the compressor was $73 and fun to do!
1 - 8 of 8 Posts
