I have an ISBe 170 from a frame cut workhorse and am trying to work out the lift pump. Workhorse wiring doc shows this.
The location on the engine has no mechanical pump...just the factory cover plate. Is this doc wrong? I imagine the lift pump was in the tank and fed power thru the I/P harness? Also any idea what stock gph and psi should be for this engine?
Any feedback is appreciated
