More cleaning,
more painting,
and liners kits arrived, sleeves are at the machine shop with the block.
more painting,
wife’s dishwasher works well.…Anything special on cleaning up parts?
No worries, I’ll keep the left turn signal full of the right blinker fluid. Hmm.. wait.… Curious on how the liners matched up without measuring.
Apparently the spring goes inside the oil ring…Having trouble wrapping my head around these piston oil rings. Could someone please advise what I need to do?
Working with OEM rings.
Without the spring the oil ring end gap is smack in the middle of the specs. with the spring I would need to remove a lot of material for the end gap to be within spec. Same deal all 4 oil rings I have, the compression rings have all been within spec.
Is that what I’m supposed to do?
I posted before I realized there was a second page to this thread. It appears everything is in order. Great work!
Both of them ended up in 60 Land Cruisers. One with an NV4500, the other H55.Great choice on the NV4500. I will be interested in following your install. I haven't kept up with what adapters are available and installs the past few years. I'm still daily driving one of my 4BD2TJ60 Land Cruisers.Did either of your 4bd2t end up in a LC?
Ah man, that’s one clean looking engine bay. Looks factory. Very nice! That’s what I would like to strive for.Both of them ended up in 60 Land Cruisers. One with an NV4500, the other H55…
I do hope you have a chance to follow along and I’m all ears to any words of wisdom you may have.…Great choice on the NV4500. I will be interested in following your install. I haven't kept up with what adapters are available and installs the past few years. I'm still daily driving one of my 4BD2TJ60 Land Cruisers.
The NV4500 specific GL4 gear oil seems to disappearing from the supply chains. You might want to get some now before it disappears. It might show up as discontinued, but here is the latest AC-Delco part# 104119 (10-4119)
Hmmm… in that case I foresee more cutting in my future. I know it has some OME springs, but if it has any lift at all, it’s 2” and my wife is vertically challenged so don’t want to go higher.Your oil pan mod is good to go if you have a lift and your engine stays to rear of engine compartment. Your pan looks just like my pan on the first install. On my second install I positioned the engine more forward and only had a 2" lift. I had to take another notch out of the pan. View attachment 134010
