I've got a 96 4bt with a P pump in an 81 Bronco. The problem I'm having is it is losing oil as I'm driving down the road, and in 20-25 miles at 60 mph it will have a film on the tailgate and back glass that with the dust you can't see through it clearly. In 50 miles it will have spit out 4-5 quarts of oil.
The tailpipe is black but "chalky", in other words it's not oil wet. The turbo tube from the turbo to the inter-cooler has no oil or oil film in it. The oil fill on the #1 cylinder doesn't have hardly any pressure coming out of the fill hole and the oil fill on the timing gear cover is the same. The crank case vent tube feels like it has about 1-2 lbs of pressure at idle and looks like it has been spitting out oil onto the front drive shaft. If you put your thumb over the tube hole for about 5 seconds it will build pressure and come out stronger for a few seconds until it levels back out.
When looking at the passenger side of the head on #3 & 4 exhaust ports it looks like it has oil around the top of the exhaust port but you can tell that it's not coming from the valve cover gaskets (dry around the gaskets).
Has anyone else ran into this? Is there a common problem that causes this? Any help would be greatly appreciated!!! Thanks in advance!
