Hi,
I was wondering if you guyz can help me with this.
I have a Cummins 6bt with a Bosch Ve pump that i am thinking to shoehorn into a 1966 Nissan / Datson Patrol G60. The power produced by the motor is just enough for the application although i would not mind if i could get more, but then i would have to mind the drivetrain, and also i think it would be more reliable if its near stock. It is a !60HP motor and it now has a 3200rpm spring.
What i need the most is the maximum amount of this torque that i can get out right from idle.(i do a lot of crawling 4 wheeling).
One way to do that is the bolt in a heavier flywheel, although it would lessen the already limited response from the engine. Can anybody suggest anything esle????Would a restrictive muffler help?
Also does compound turbos decrease the turbo spool up time or increase it. I plan to use the hx35 as the largr turbo along with a very fast spooling turbo from a 160ci motor(i dont recall the model right now).
Regards,
Bikram
Regards,
Bikram
