1 - 8 of 8 Posts
Hey everyone,
I've come across some LPG 6bt's what is involved in converting them to diesel? Pistons, head, cam, timing cover and a pump etc is there a simpler way? Are quite cheap so just thinking about it....
James
I'm sure it can be done but not sure it would be cost effective. Don't know that we've ever had anyone do one on the forum.
For many years I pondered the thought of converting a B-Series LP engine to run on gasoline. I often wondered if it would be a torque monster running at a low RPM which would give it a long life and great fuel economy but be using a cheaper fuel than diesel.
Would be sort of unusual for an LPG engine to have that low CR. LPG has a much higher octane rating than any gasoline including racing fuel. It could easily run 14:1 or higher.
Do you know what boost levels they ran?
Discussion Starter #7
I guess 14:1 naturally aspirated... Put a turbo on then comes down as the boost goes up.
Hey everyone,
James
I have a 6bt that ran natural gas which is the same engine, you only need to change the pistons and cylinder head. I'm not sure on the cam but they have the p pump timing cover so you'll just need a pump and pump gear
1 - 8 of 8 Posts
