I'm working through a 1973 Bronco rebuild with a 4BT. I have both the mechanical and hydraulic clutch mechanisms but the bellhousing that was mated to the 4BT is cracked in the transmission centering bore. I believe that I can make the original Bronco mechanical clutch linkage work and use the original steel bellhousing. Has anyone used a similar mechanical clutch setup with a 4BT? If you did, what issues needed to be resoved?
Thanks in advance for your help.
James
James
