Your very close, a little under 700.I have been looking for gauges also. It seems that if you want gauges to match you are limited by which ones have diesel tachs. I was looking at the Auto Meter 2 5/8 unit at Jegs. It sells for $135 there but was out of stock last weekend. It is a Sport-Comp which matches the Pro-Comp gauges. By the time I would buy a full cluster of gauges like Paul (in NY) has in his dash it would cost $717. That is a bit pricy for me. After selling off the scrap and a few parts of my P30 that is about what I have in the motor. Some of the gauge companies have an industrial line that is a little cheaper don't they? Are they decent gauges?
The VDO Vision Series Boost is mechanical.I couldn't find a VDO electrical boost gauge when I was looking. EGT and temp gauges make sense to be electrical.
Yes, that's the one I have in 0-30psi paired with their metric EGT gauge. You could use their electrical oil pressure gauge for boost, but the scale is somewhat higher (around 80psi I think).The VDO Vision Series Boost is mechanical.
Paul
Dougal; have you seen the vision series backlighted Green at night. I have a picture of the panel I posted above in very reduced light so the gauges show up. Let me know if you want to see it.Yes, that's the one I have in 0-30psi paired with their metric EGT gauge. You could use their electrical oil pressure gauge for boost, but the scale is somewhat higher (around 80psi I think).
I'm also using green backlights to match the original instruments.
Sure, post it up. I'll try to get pics of mine later tonight when it's dark.Dougal; have you seen the vision series backlighted Green at night. I have a picture of the panel I posted above in very reduced light so the gauges show up. Let me know if you want to see it.
Paul
Here s a link to the picture to save forum space. A few of the gauges were missing the green filters as they were back ordered.Sure, post it up. I'll try to get pics of mine later tonight when it's dark.
Nice.Here s a link to the picture to save forum space. A few of the gauges were missing the green filters as they were back ordered.
http://photos.imageevent.com/moosecreekmaple/m37project/websize/32030907a.jpg
Paul
I put resistors inline with each of my extra gauges, change the resistor size until the brightness is roughly uniform.Paul would you say that your VVO gauges are fairly consistent? With my Autometer Z gauges I noticed some way brighter than others. Drove me nuts, actually![]()
