Keep in mind the 4D55/56 uses the Wideblock Bellhousing Pattern that was commonly found on the Mitsubishi 2.6L in the Ram 50 trucks, Mazda only used that bellhousing in the B2600 series for 1 or 2 years, pre-fuel injection years i beleive. After that it has it's own unique bellhousing pattern for the 2600i.
So you may need to source a transmission/transfer case for the truck, if yours isn't one of the years that shared the same bell pattern. And the Diesel Starter is a must have, the gas one just doesn't have enough reduction to spin the engine over effectively
