mystery bell pattern and flywheel
Borg-Warner 4 speed tranny t19 married to a 87 4bt
is this a gm pattern bell or a ford pattern bell? sure looks like a ford pattern but is the ford pattern commonl;y 385 series or small block
objective is to run a short 6.5" input equipt nv4500 originally i am thinking gm flywheel to AA gm bellhousing for a nv4500
thoughts?
__________________
1979 cherokee chief 401 nv4500/D300 4bt canidate
2003 Dodge 3500 4x4
1996 F250 cummins convert 1999 NV5600/ 12v wh1c/ht3b twins np205 D60/D80 power loks F&R 400k miles - sold 2003
1998 dodge 12v nv5600 4x4 twins hx35/s400 185k - sold 2006
dusty
View Public Profile
Send a private message to dusty
Find all posts by dusty
Add dusty to Your Buddy List
#2 07-18-2007, 12:39 PM
averagef250
Registered User Join Date: Jun 2007
Sounds like a small block Ford bellhousing T-19. You can mate a dodge NV4500 to a Ford bellhousing with an AA plate.
__________________
Dustin
Manual Transmission Service
1970 F-250 4x4 ZF S6-650 6 speed NP205 HP60 D70B 35" BFG Muds 12V swap in progress
1971 F-250 4x4 M5R2 BW1356 HP44 D60 35" BFG Muds 4BT 20 MPG city 26 freeway
#3 07-18-2007, 06:17 PM
4bt Terra
Registered User Join Date: May 2007
Forget the AA plate big $$$$ just use dodge 6bt flywheel cover and nv4500 bellhousing usually around $100-200 for the pair and it bolts right up.
#4 07-18-2007, 06:21 PM
averagef250
The AA plate is $200. ****EDIT***. Sometimes the mechanical clutch linkage is nice to keep in an older truck.
__________________
Dustin
#5 07-18-2007, 10:07 PM
dusty
Registered User Join Date: Jul 2007
the only down side about the plate is i would have to buy a new input shaft for the nv4500 already in the jeep.
i already have a dodge bell and flywheel but im hoping to ditch them in search of a gm flywheel
Oh yeah already have a 4bt with a rod hanging out of it and a gm adapter....
so i have
ford adapter ford flywheel
Gm adapter no flywheel
Dodge flywheel, dodge bell (down side is dodge uses hydraulic i want to maintain my linkage)
NV4500 with short 6.5" input shaft
I do have access to a CNC machine so i could take the gm adapter down and have a friend recut one 10* clocked.
__________________
#6 07-19-2007, 12:03 AM
averagef250
I'll do you even better... ****EDIT**** the light duty 1 1/8" dodge input will go with the AA plate ***EDIT*** but it won't fit the low first '95 and earlier NV4500 though.
Sounds like you've got a pretty good handle on it though.
I just hate the 8 degree or so chev/cummins adapter angle.
__________________
#7 07-19-2007, 06:34 AM
dusty
***EDIT***
thats interesting now currently my nv4500 tranny has the 1-1/8" input which is 6.5" long the stock dodge is 7.25" long and 1-1/4" my understanding is the ford bellhousings are 6.5" deep so adding the plate would add 3/4" which would necesitate tracking down a 7.25" input and a different clutch? right? if the input shaft you have is 7.25-7.5" from a dodge gas rig and 1-1/8" id possibly be interested in looking at that swap
Your onto my line of thinking i want to keep the old mechanical linkage, ultimately id like to make it where the bellhousing and the engine are the only two things that need to come out. so that if i ever want to stick the 401 back in for some saturday night entertainment i could and it wouldnt be a major undertaking.
__________________
#8 07-19-2007, 10:53 AM
averagef250
I don't know the measurements, but the dodge light and HD input shafts both work with the AA plate and any Ford truck bellhousing.
You will need to change the clutch disc as Ford is 1 1/6 10 spline. You'll need a chevy/dodge 12" 1 1/8" disc.
__________________
#9 07-19-2007, 12:37 PM
dusty
well im interested now in looking at that avenue.
gotta do a little research on the input bearing retainer as mine was a dodge thick unit that i machined down to work with the chevy/jeep throw out bearing as per AA and thier bellhousing but you might just have a buyer for those pieces.
thanks ford tid bits on adaptability of these parts i think i might be formulating a different plan on how im going to tie my 4bt to my nv4500
__________________
Edited thread removed offers from helpful parties offering possible solutions via spare parts they had lying around to id my quest for an answer to adapting my nv4500 to the 4bt. In the future if you think you have a part that might be of asistance please dont offer it on thread aparently that is a conflict of interest with vendors so best to keep that good stuff to pms. hopefully this thread will provide mor einfo for others seeking to marry a nv4500 also.
THANX
thoughts?
__________________
2003 Dodge 3500 4x4
dusty
View Public Profile
averagef250
__________________
Dustin
4bt Terra
averagef250
__________________
Dustin
dusty
so i have
__________________
averagef250
__________________
dusty
***EDIT***
__________________
averagef250
__________________
dusty
__________________
THANX
