1 - 20 of 49 Posts
· Registered
Hey guys I have a coolant leak from my 4BT and am convinced it’s my freeze plug , but I wanted to do my due diligence first before pulling the trans and T case to make sure that’s what it is . There’s coolant leaking from the bell housing cover dripping down to my sway bar and trans . No other obvious leaks . And unfortunately no access to the rear freeze plug due to the AA adapter to my 4L85E trans…. Anyone have the Cummins # for the rear freeze plug or pictures so I can see what I’m working with , couldn’t find anything on the web.
· Registered
Only other place might be the rear location on the left side of the head for a temp sender. If it is the head you might look at my post about my head bolt failure. Best to go back with studs and make sure to get a quality gasket. Pressurize your system at the radiator and let it sit cold. Should help you find out for sure where the coolant is coming from. Jmtcw
· Registered
Discussion Starter · #9 ·
The one near the top of the block is covered by the Advanced adapters adapter plate , it’s very large , but based on what I saw , it’s leaking behind cylinder 4, not very happy about this, seems like it’s been one thing after another unfortunately
· Registered
Make sure the head is not cracked, not common but rule it out....
· Registered
Cummins has a lower engine gasket kit which is part 3802375 which sells for $519.10. That is every gasket and seal below the head. That is a complete rebuild kit. The head gasket and exhaust gaskets are not included in that kit. Standard head gasket is part 3283333 (.25mm oversize is 3283336 and .50mm oversize is 3283338), valve cover gasket 3930906, oil filler cap gasket is 3936876, intake manifold gasket is 3938153, aftercooler inlet gasket is 3914856, exhaust manifold gasket is 3927154, turbo inlet gasket is 3709861, and turbo oil drain gasket is 3765575. All the gaskets and seals in that big kit can also be bought individually. There are 38 different parts in that kit. There are 2 different filter head gaskets in the kit depending on which block arrangement you have. Early engine types use gasket 3929792 shown here.
Sports equipment Font Fashion accessory Titanium Plant
Later engines use gasket 3942915 shown here.
Font Sports equipment Gadget Fashion accessory Metal
Here are all the gaskets in the big kit.
Parts Catalog
RefPart NumberDescriptionQuantity
3802375LOWER ENGINE GASKET SET0
13283767PUSH ROD COVER GASKET1
3901020PISTON COOLING NOZZLE4
23902425SEALING WASHER2
33903475RECTANGULAR RING SEAL1
3905595TIMING PIN HOUSING GASKET1
43906696RECTANGULAR RING SEAL1
53906697RECTANGULAR RING SEAL1
63906698RECTANGULAR RING SEAL1
73908096COVER PLATE GASKET1
83912473RECTANGULAR RING SEAL1
93913994O RING SEAL1
103914385GEAR COVER GASKET1
113915772RECTANGULAR RING SEAL1
3915800RECTANGULAR RING SEAL1
123916042HYDRAULIC PUMP GASKET1
133920773SEALING WASHER1
143928759GROMMET SEAL6
153929751ACCESSORY DRIVE COVER GASKET1
163929792FILTER HEAD GASKET1
173933261DUST SHIELD1
3934486RR CRANKSEAL SERV KIT1
3904325SEAL INSTALLATION TOOL1
3909409SEAL INSTALLATION TOOL1
185259499OIL SEAL1
3937111FRONT SEAL SERVICE KIT1
3904351SEAL INSTALLATION TOOL1
3904352SEAL INSTALLATION TOOL1
193935959OIL SEAL1
203937214PISTON COOLING NOZZLE4
213938156GEAR HOUSING GASKET1
3938157FLANGE GASKET1
223938162OIL PAN GASKET1
233939258COVER PLATE GASKET1
243939355FUEL PUMP GASKET1
253942915FILTER HEAD GASKET1
264932124OIL COOLER CORE GASKET1
274947667REAR COVER GASKET1
284988280HYDRAULIC PUMP GASKET1
Font Slope Urban design Diagram Art
Have fun.
· Registered
Discussion Starter · #15 ·
Here’s some pics of the head gasket the leak was behind the head above the trans steady leak , but no noticeable coolant mixing , a little ugly , not sure what made it go , high EGTS? High cylinder pressure ? Only running H1C for now , highest I’ve seen is 1300 climbing up a grade , will bump the timing back a little and hopefully head studs , and the new super 30 will help lower the EGTs to avoid another situation like this …
Brown Automotive engine gasket Auto part Circle Audio equipment
Audio equipment Art Circle Auto part Visual arts
Brown Bicycle part Rim Auto part Circle
Hood Motor vehicle Automotive tire Vehicle Automotive design
N
· Registered
Was sort of wondering the same thing since there are 2 bolts right near that leak. Might also check the head for any warp. You mention cutting back the timing. Usually advanced timing doesn't cause higher EGT but it can result in higher cylinder pressure. Having too much fuel and not enough air is usually the root cause of EGT. That H1C is at the heart of that. Although not everyone does it, but an exhaust back pressure gauge is a good one to have in vehicle. You can build one yourself using a second boost gauge or there are dedicated ones available. They tend to be fairly expensive but good info is worth the cost. Those gauges are electronic where the one you build would be mechanical. The one caution there is you'd have a CO source inside the vehicle. If done correctly you'd never have a problem but a CO detector in the cab would be cheap protection.
· Registered
Discussion Starter · #18 ·
I never touched the head bolts , I haven’t done anything with the head besides injection pump , timing , fuel pin , gov spring , injectors , so it’s a surprise they would be loose. One thing I did notice is when pulling the bolts the back head bolts were dry and the rest had oil
1 - 20 of 49 Posts
