1 - 1 of 1 Posts
hello look for some help a bought a 2001 dodge (cummins 5.9) 24V Motor to put it in an older bus 1999 (Same Motor) but being it's a truck motor things needed to be changed but one problem l ran in to was with the crank senser the older 5.9 senser is in the back and the crank has teeth on it the newer (2001) 5.9 is different no teeth and the hole for the senser is covered l have read that there was a change in 2001 and the senser was moved to the front is there a way of useing the older bus wiring with the new motor ??? the only thing l can think of it replace the new crank with the older one any help whould be great thanks
1 - 1 of 1 Posts
