1 - 6 of 6 Posts
if it helps you cant over fill it. if thats your concern if you fill it through the top fill hole on the back side the extra oil will just run out once it fills up to the hole. i think the last time i filled mine it was a little less than a gallon maybe three and a half quarts. steve.
But what if you clocked the 205
Mine sits dead flat with the outputs pretty much level.
Banned
Dont matter.
is that because the 10* tilt on the cummins gm adaptor. i think im going to sit the motor stright and tilt the trans and tranfer case. the tilt will help with ground clearence with the np205. does anyone see a problem with tilting an nv4500 and np 205 as long as the corret amount of gear oil are in them.
1 - 6 of 6 Posts
