1 - 8 of 8 Posts
Anyone else ever get a bad shudder when towing with the 4bt/nv4500 combo? It feels like bad clutch shudder but I only get it heavily loaded in 4th.
I'm running a Luk single disc clutch rated 350hp/590tq. 3.73's and 33's and I have a good set of traction bars so I can rule out axle wrap. Clutch and u joints were new when I did the swap 4k mi. ago
This is in a 96 k1500 with the factory 10 bolt posi, the trans was out of a 06 Chevy city maintence truck with 30k mi. on it so I hope it it's good. And it can keep up with our 300hp/520tq lb7 d-max so I know I ain't pushing the limits on the clutch.
Ideas anyone??
Thanks, Glendon
This sounds a bit like the old Chevy 4 speed stepvan problem of a clutch disk that has lost a couple of springs in the disk. Luk is a good clutch but can develop this problem when it is abused.
Didn't elaborate on if it shuddered just when shifting ,or all the while in 4th... if it shudders all the while in 4th and loaded, then it could be the driveshaft is binding from the springs being compressed while loaded.....
Yeah, it shudders all the while under boost below 2100 or so rpm and heavily loaded in 4th, 5th is smooth, 3rd can vibrate a little sometimes too but again only when loaded heavy and not a shudder like I get in 4th.
Like I said, check driveshaft. Could be bottoming out ,causing the driveshaft to bind and shudder......would be my first suspect,as I have seen it happen. ..... dirty injector could cause a shudder as well, but could be detected in the exhaust sound.
Check the pilot bearing. A worn pilot bearing causes that exact problem.
Discussion Starter #8
Thanks for that suggestion, it got me thinking and I remembered that when I bolted my trans up the one locating dowel was missing, so I just eyeballed it and bolted it down. So I checked and sure enough it had moved, so I slid the trans back an inch and made a locating dowel to keep it centered. Back together and much improved, the shudder is gone but there is still a harsh vibration. If I roll down the window it sounds like someone taking an air hammer to my aluminum driveshaft.
I also checked the driveshaft and it's not binding and the u-joints seem good.
1 - 8 of 8 Posts
