1 - 4 of 4 Posts
i'm looking for a clutch release fork for an nv4500 behind a 4bt. looked all over the internet, but i can't seem to find one.
Brian
Brian
we need a little more info.
since the nv4500 didnt come as an option behind 4bt's what bellhousing, flywheel, engine adapter and model of nv4500 are you using.
For example a late model gm nv4500 uses an internal slave and no thowout fork. so it's bellhousing wouldnt have a pivot but an early model bell will
Dodge has a different bell than a GM, different depth and different pivot. all dealership stuff. 94-02 dodge diesel bellhousing, pivot and fork and engine adapter plate from dodge with a nv4500 is same. 89-93 if it has a nv4500 uses an advanced adapters bellhousing to the earlier style adapter plate and uses the dodge 89-93 clutch fork and pivot.
Think back a ford using a NP435 uses a different clutch fork than a dodge with a np435, likewise a gm with a np435 also has its own specific fork.
so the devil is in the details especially if you are attempting to use a adapter plate to tie the nv4500 to a non-nv4500 specific bellhousing.
good luck
If you have a Dodge bellhousing than your local Dodge dealer can get them as well as the ball and clip .These # 's are for the Dodge Bell housing 94-2001
Fork 52087515
Ball 52087542
clip 4338855
Scott
1 - 4 of 4 Posts
