1 - 3 of 3 Posts
ok here is my plan. 4bt nv4500 np203/np205 crawler...ish
i have a nv4500 out of a 99 dodge diesel 29 spl output. i kneed to change it to a 32 spline out put to mate to the np203.
also i kneed a adaptro plate that goes between the funkey bolt pattern on the np203 to the 6.75 -6 round pattern on the nv4500. a :idea: hit me when i herd that some of the th400 had a round pattern on them and i found this
so my 2 questions are
1 will a shevy 4x4 output shaft work on my dodge nv4500 hd
2 will the th400 np203 adapter work on the nv4500 round pattern?
(i tried google and other searches but the info just isnt hitting me for some odd reason)
The "output shaft" in a manual is the mainshaft. You can put a GM shaft in a dodge NV4500HD, but you'll need a new 5th gear and nut.
You'd need to measure the length of the GM VS dodge shafts as well to determine what tailhousing you'd need to use a long with the mainshaft.
i am running twin transfer cases
In my case a NWF black box and a 205. 5.53 to 1 is my lowest gear with this combo. Got a crawl ratio of 153 to 1 .
Should be good enough to crawl through the odd ditch .
Bruce
1 - 3 of 3 Posts
