One of my NV-4500's is the gas version. I changed the input shaft to the 1.250" x 10 spline as used on the NV-4500HD so I could use the Dodge/Cummins Clutch. Quick/easy change, just watch the end play when changing the input shaft, you may/may not need to shim. Follow the manual specs.So I know I need all the 94 up dodge stuff but my ? is. Can I use a gas nv4500 without any mods? I need the 23 spline output for my tcase and want to know if I have to swap input shafts or not?
Thanks, Adam
Thanks, what I wanted to know :grinpimp:One of my NV-4500's is the gas version. I changed the input shaft to the 1.250" x 10 spline as used on the NV-4500HD so I could use the Dodge/Cummins Clutch. Quick/easy change, just watch the end play when changing the input shaft, you may/may not need to shim. Follow the manual specs.
Paul
