1 - 9 of 9 Posts
Could someone please confirm what thread the oil filters have in a GM-style breadvan 4BT?
Thank you.
WixFilters.com says 1" 16:
Part Number: 51602
UPC Number: 765809516021
Principal Application: Agco, Case, Consolidated/Cummins 3.9L Engine, I-R, Komatsu, Other
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.214
Outer Diameter Top: 3.663
Outer Diameter Bottom: Closed
Thread Size: 1-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=11/25
Burst Pressure-PSI: 375
Max Flow Rate: 12-16 GPM
Nominal Micron Rating: 17
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.255
Looking at that, it's a different filter:
LF3970 FLEETGUARD FTG 57182
Specs on Wix 57182:
Part Number: 57182
UPC Number: 765809571822
Principal Application: Case Excavators, Cummins B Series Engines, Komatsu Excavators
All Applications
Service: Lube
Type: Full Flow
Media: Wire/Paper
Height: 6.940
Outer Diameter Top: 3.670
Thread Size: 1 1/8-16
Beta Ratio: 2/75=10/30
Burst Pressure-PSI: 300
Max Flow Rate: 18 GPM
Nominal Micron Rating: 10
Gasket Diameters
Attached 2.829 2.459 0.235
Is yours for the vertical mount, or the horizontal one? I got the 51602 from application lookup on Wix's site.. Walking out to the truck to confirm now..
Yep.. Horizontal mount is LF3345 / 51602 / 1602 per sticker in truck, filter spun on is 1602 NAPA.
Discussion Starter · #7 ·
Just got home and checked - Looks like 1-16. None of the remote filter kits I've found has that thread :(
What does the 10756 kit have? It is for the 5.9 Cummins.
Are not the 3.9 and 5.9 the same filter thread?
The thread size is 1" x 16 tpi. Same for 5.9 and 3.9. This is why I made the remote adapter for my conversion with that particular thread size and pitch - so I could use the same filter on the Dodge and the Chevy. Check with your Fleetguard supplier for a remote filter adapter with that thread.
1 - 9 of 9 Posts
