1 - 1 of 1 Posts
Banned
another thing to consider that has not been mentioned is adding oil capacity to the oil pan. this is a easy to do mod.. when you turn up engine rpm,s or go for hi-power output this is a highly recomended modification just like in any performance engine. it also helps to keep the oil temps down . another thing to consider is installing a air cooler in the stainless braided line from the oil cooler going to your turbo . this will give extra cooling to the turbo lube oil. just tricks i learned from my trucking days trying to make power safely.
bob
1 - 1 of 1 Posts
