Are the oil pans bolt pattern reversible? IE can you turn a front sump around to make a rea sump?
tndonor · Registered Joined Jan 3, 2007 · 329 Posts Discussion Starter • #1 • Feb 18, 2007 Are the oil pans bolt pattern reversible? IE can you turn a front sump around to make a rea sump?
P Paul(in NY) · Registered Joined Jan 4, 2007 · 808 Posts #2 • Feb 18, 2007 Yes, reversable. But you will need to get a different oil pickup. Front Sump and Rear Sump are different. Paul
