Whay the 6bt does 22 mpg and the 0m352a does 12 mpg? if the 6bt is 5.9 and hier revolution and the 0m 352a is 5.7 and lower revolution? is it the fuel
Even if that engine came from a tractor?Perkins for automotive use requires damper on the front of engine, otherwise short lived!
Ed in CO
Yes. It's a rpm thing. In a tractor they probably never go higher than 2000rpm. Automotive the problems start over 2000rpm.Even if that engine came from a tractor?
I have in YouTube videos seen they are getting up to 3500 rpm. But you are right about harmonic balanser. I have seen in "videos" they have swapped tractor harmonic balanser to a car fluid harmonic balanser to prevent crank breaking. Maybe balancing the rotating assembly in the engine could be a preventive factor so the crank shaft does not break.Yes. It's a rpm thing. In a tractor they probably never go higher than 2000rpm. Automotive the problems start over 2000rpm.
6 cylinder diesels need a crank damper on the front to stop harmonics at higher rpm. It's the harmonics that eventually break cranks.
