1 - 2 of 2 Posts
I've read that the fuel line in the w126 is insufficient and can cause insufficient flow and fuel vaporization.
I believe I've deduced a solution, pressurize the line.
I bought a mr gasket 105 gph pump capable of 14 psi with a regulator 4-14 psi. I also ordered the neccesary fittings, hoses and clamps. I'll pull a relay and some wiring from a car in the junkyard and keep you folks updated.
Guys have made 500hp with the 606 on stock lines and filter. So you should be ok.
I think you need a fuel pressure regulator for the higher rpm range though, if you have a superpump anyway.
Sent from my SM-G955U using Tapatalk
1 - 2 of 2 Posts
