does anybody have a part number for the ford small block adaptor plate? has anybody ever bought one new , iwas wondering how much they are.. will the flywheel from a cummins 6bt and a getrag trans work with this adaptor. thanks for any help.....
The part number is in this thread: http://4btswaps.com/forum/showthread.php?t=841
I don't think you are going to locate a new one through Cummins. The Dodge 6BT flywheel will not fit into this adapter because it's way too big. The 4BT step van adapters use a flywheel with a ring gear outside diameter of approximately 14-3/4 inches whereas the Dodge 6BT measure about 15-1/4 inches. If you intend on using the Getrag G360 you should consider using all the "family" related components that it came with.
1 - 2 of 2 Posts
