1 - 3 of 3 Posts
I am swapping a ALH into my 1986 toyota pickup, I have a chance to buy a brand new turbo off a 2005 passat and I can get a manifold. Would this set-up work with my 2002 ALH with a 11mm pump and stage 2 tune. Also what nozzles would I use for this setup
The best turbo for your ALH is the turbo from the BMM. The BMM was the highest performance 8V motor at 103kw and the turbo was the GT1646V integrated into the manifold. The 16V motors have better airflow so can run bigger turbos which will lag a bit on the 8V engines.
Do you know which engine the passat has? My quick internet search says BRM which was 74kw.
That turbo will work great and give you ~180whp. Run pp764 or R520s.
1 - 3 of 3 Posts
