Ok, so what are the benefits of a 6BT over a 4BT? I have the 1 ton axles so the weight isn't a factor but what should I be looking at in terms of power output, one vs. the other (in stock form)? Also, what is the weight difference between the two? I have a Jeep Wagoneer so I'm not too worried about an offset weight ration like most trucks have problems with. Also, does anyone know of any owner-sites or anyone I can personally converse with that has swapped in a 6BT into a SJ? I know the front clearance will be minimal and almost certainly need an e-fan, but other than that...? Ok, I'm done rambling.
Thanks in advance guys/girls!
