1 - 3 of 3 Posts
I want to figure out the pump shaft drive ratio of the Saginaw P-pumps that are bolted to the timing case using the cummins gear and adapter. The p/s pump gear is 37T according to photos I found & the crankshaft gear is 36T (I think). Can anyone confirm these numbers?
I believe you're correct. That's the count I get on both gears. Don't have a crank gear handy but do have PS pump gears. I looked at good photos and get the same answer you have.
1 - 3 of 3 Posts
