1 - 18 of 18 Posts
I thought that I'd throw this question out and see what kinda answers I get. I'm working on putting a 4BT into a Chevy S10 Blazer with a curb weight of 3776 lbs and I was wondering what kind of transmission I could mate up to it for the least amount of $$. I'm not trying to be cheap, just working on a budget. I was thinking of a NV3500/3550, but I'm not going to baby this thing :tongue: . I also don't want to use a heavier transmission if it's going to be overkill.
I was thinking of the NV4500 ( I am looking for a manual with O.D) but I'd like to see if there's anything else out there that's cheaper than that. I also need to be buying the adapter plate to mate the tranny to the engine as well.
Detroit Section Caretaker
I have not heard it mentioned here yet, but in a light vehicle, how about a T5 from a mustang?, S10, and similar vehicles. They stand up to strong V8's, and can be made even stronger. They fit where an SM420 or SM465 fits, so not a problem.
A friend is going to run one behind a 3-53T in a small Chevy truck, not sure if he has swapped it in yet or not.
I would not use it for towing or in a heavy truck...
Grigg
Discussion Starter · #4 ·
check out the ZF5, if you can find a 4bt with a ford adapter you would be set.
Diesel Durango, would you be referring to the ZF-S542/ZF-S547?
I'm getting an engine from CrewCab59. But I don't think that it has an adapter on it, and I've shot my budget for the next month :p
Pantherman
Grigg
Avoid the T5, it's junk for a diesel, and wasn't even strong enough to hold up behind a stout gas V8
OK, if the T5 is no good, then I thought someone made a better one based on the T5?
Is Tremec the manufacturer of the T5, or do they offer a better one?
And how about the Richmond 5 and 6 speeds?
Grigg
I agree about the T-5. Although the ones used in Camaros and Mustangs were marginally stronger than what was used in S-10s and Jeeps, they were still weak transmissions. I can't count how many Jeep ones grenaded behind 4 cyls!
A transmission that is much stronger than the T-5, although still marginal for a 4bt, would be the AX-15 used in Jeeps in the 90's. You can bolt it to a 4bt using a Dakota bellhousing and Dodge adapter.
Jim
The tremec TKO 600 is at least twice as strong
Unless it's a only an off road vehicle overdrive is pretty much required, or at least it will be greatly appreciated.
Discussion Starter · #14 ·
Which is why I want a transmission with O/D, and a manual at that. Nothing personal, I just like manuals a lot more than automatics.
Pantherman
Discussion Starter · #16 ·
I thought the ZF-5 from a smallblock worked pretty damn good. I'm selling mine now if you need it.
Is a ZF-5 the ZF-542/ZF-547?
I'd like to but my budget's gone for the next month (December).
I don't think you can get any tougher for the same price as the S5-42. Plus the Ford manual adapters are the cheapest of all of them. And they're not tilted.
The T-5 is crap. The AX-15 would lose 5th gear in no time behind a diesel and you'd have a large expense for an adapter. By far the cheapest option would be the M5R2, but if your really going to pound on one I think I'd go ZF.
Discussion Starter · #18 ·
What about the NV3500? I mean this is going into a 3776 lbs frame.
Pantherman
1 - 18 of 18 Posts
