Status
Not open for further replies.
1 - 10 of 10 Posts
Looking to purchase the input gear for a Chelsea 352 PTO for the early Chevy NV-4500 (different than the later Chevy/Dodge version). I can provide part numbers if needed.
I have a PTO with a different input gear but might consider a complete PTO if the gear is right.
True, but I don't have to have it to finish my project, so I can afford to wait.
I posted from work initially and didn't have the details.
The Parker Chelsea input gear number is 5-P-1063.
Bulletin HY25-2352-M1/US lists it as a 25 tooth left-hand helix gear.
The PTO model would start with 352XSFB.
The latter dodge version used a 26 tooth gear one number/letter designation higher.
Since both transmissions are no longer in production neither are the gears, so the distributers can't get it.
I found one for the Dodge NV4500, 5-P-1064, for $88, but that won't help you any, unless you swap to the later input and cluster gear.
I looked at my PTO and it's a totally different model number, 381XBLS-4, from yours.
Mark.
Discussion Starter · #10 ·
Yes yours is designed to drive a hydraulic pump, the 352 is designed for shaft drive which is what I need to run the winch on my truck. Hadn't checked but I figured the input gears were the same for the different PTOs.
1 - 10 of 10 Posts
Status
