Gregg,Nice idea, I have been trying to figure out how to run a vacuum pump. I have a Ford PSD vacuum pump lying around that just might wirk like the one in your picture. I can't fit a typical Cummins vacuum pump due to the engine mounts.
I remember your pump setup, I took a long look at using a Dodge pump but like I said it pushes my P/S pump back in the way of where the left engine mount will bolt up at. I even went so far as to remove the vacuum/P.S. pump combo from my Dodge and bolt it up to the 4bt. So I thought I could use the PSD pump I have lying around. I also checked into hydro boost brakes but it is rather pricey.Gregg,
That is not how my vacuum pump is set up. I am using this picture for a reference for the pulley on the fan drive. My vacuum system is off the dodge ram. It looks just like the picture below. I just moved my alternator where the vacuum pump is. I didn't have enough belt touching my alternator to make it work without squealing.
Mooktank do you have the part number that is on the pulley??I have one and will be selling when I convert to hydroboost. Anyone make hydraulic hoses for a living that might want to trade?>
Cummins 3903221Does anybody have the part number for the v-belt pulley that is used on the ford setup on the 4bt with the vacuum pump?? I need the pulley that attaches to the fan drive pulley.
Thanks for the info. I haven't tried the local cummins place yet but I will now.The new PN for that pulley is 3919624, and was $33.32 when i ordered it from Cummins Atlantic this morning. It's listed as a freon compressor pulley.
