1 - 2 of 2 Posts
I havent been on this forum in a while although I've done a couple cummins swaps into chevys in the past. I recently picked up a low miles 6.2 truck and the trans seems to be bad as it won't shift out of first. it has the700r4. Is this trans specific to this truck or can I pick up another 700r4 and swap it? Are there any mods that are needed. The truck has less than 88k on the clock. I think I will keep it and let my kids drive it but I want it to be dependable. Thanks for the help
The 700R4 behind the 6.2 used a different torque converter, governor, and maybe the valve body as well, to be better set up for the lower RPM peak torque. A diesel 700 would be preferred, but you could swap those components. May be better to rebuild the existing one and make some upgrades at the same time. Hope that helps and enjoy the K10. Joe.
1 - 2 of 2 Posts
