Those are some of the base parts but there are quite a few more pieces to that puzzle. Injection pump 3917530 would be a good one. That is a pre emissions model that does not have the KSB option so that won't need the sensor and wiring for that. For that pump you will need the following parts:
3905313 Pump Support Brace
3900630 M8x1.25x20mm Flange head bolts 3 required
3902501 M8x1.25x47.98mm double ended stud 3 required
3900589 M8x1.25 Flange head nuts 3 required
3931607 Pump gasket (this part is obsolete and shows no replacement)
4932713 Pump drive gear (old numbers were 3929032, 3931383, 3936021)
Next comes the air fuel control plumbing.
3282437 Air fuel control tube
3905391 Grommet
3918188 8mm Sealing washer 2 required
3910265 Male elbow
3924724 M8x1.00x17mm Banjo bolt
Next will be the lift pump and plumbing.
4983584 Fuel transfer pump (old numbers 3928143, 3966154, 3970880)
3905649 Fuel supply line
3939258 Gasket (old numbers 3923054, 3931059, 3931348)
3963983 Sealing washer 2 required (old numbers 3918191, 3935171)
3903035 M12x1.50x24mm Banjo bolt
3900631 M8x1.25x25mm Flange head bolt 2 required
Not sure about your fuel filter arrangement but here is the normal parts for this setup.
3925954 M16x1.50x33.5 Filter head adapter
3286503 FS1251 Fuel filter (old number 3931062)
3911446 M12x1.50x24 Special banjo bolt
3939570 Captive washer cap screw (old number 3905403)
Now for the major mess of plumbing. With your current injection lines you may already have these support braces but I'll list them for you. With this group I'll show the item number in the drawing. You'll have to sort out what you have that is reusable.
1 3928759 Grommet seal 4 required
2 3900629 M8x1.25x16mm Flange head bolt 2 required
3 4942278 Banjo connector seal 4 required (old number 3903380)
4 3918109 M8x1.25x25mm Flange head bolt 2 required
5 3905307 M6x1.00x14.3mm Banjo bolt 4 required
6 3905388 Male T union
7 3905692 Fuel drain tube (return to fuel tank)
8 3905701 Fuel drain tube (from injection pump)
9 3920854 M5x.80x22mm cap screw 4 required
10 3903723 5mm plain washer 4 required
11 3919294 Tube brace
12 3904711 Tube brace 4 required
13 3917746 Vibration isolator 8 required
14 3903480 #1 Injector line
15 3903481 #2 Injector line
16 3919292 Tube brace
17 3903482 #3 Injector line
18 3903483 #4 Injector line
19 3909695 Fuel manifold
20 3905391 Grommet seal 3 required
21 3919296 Tube brace
22 3919381 Tube brace
Injectors specified for the VE pump engines is part 3802330 or 3802330RX for rebuilt units. Injector seals for the 7mm head are part 3906659. You need to verify what size injectors holes your head has. I suspect it is 7mm but original VE pump engines came with 9mm. Cummins no longer sells the 9mm injectors and these are the newer 7mm replacements that have the correct pop pressure and 12mm threads on top like the OEM 9mm units.
On the front gear housing, here are the part numbers.
1 3938156 Gear housing to block gasket (old numbers 3916131, 3931351)
2 3920758 Gear housing (old number 3802350)
3 3900633 M8x1.25x50mm Flange head bolts 10 required (reuse the old ones)
4 3924962 M8x1.25x16mm Flange head bolts 16 required (reuse the old ones)
5 3915772 O ring seal
6 3913994 O ring seal
7 3903924 Timing pin
8 3904849 Retaining ring
9 3919683 Timing pin housing
10 3907998 M5x.80x17mm Screw
11 3914385 Front cover gasket (this is normally done with RTV instead of the gasket)
12 3287075 Front cover (old numbers 3903794, 3286312)
13 3937111 Front crank seal kit (old number 3900709, 3904353)
14 3901446 M8X1.25X60mm Flange head bolt
15 3912772 Belt retainer
While you're in there be sure to do the killer dowel pin repair. In which position is you oil pan sump? If it is front you'll probably need to reverse the pan to rear position. To do that will require a new oil pump pickup unit. You will need a new oil pan gasket anyway.
3938162 Oil pan gasket (old number 3931602)
3905206 Rear sump pickup
3938157 Pickup gasket
3907860 M8x1.25x25mm flange head bolt (pickup brace to block)
Hope this helps. I hope I didn't mistype any of these part numbers. Are you changing exhaust manifolds? I see the Super HX30W turbo on your list. That one will require different oil line plumbing and air outlet elbow. Let me know if you need anything else.
