Alrighty, I spent some time this weekend pulling the fuel tanks and gutting the fuel pump assemblies. But before that, I got the exhaust plumbed up.
I bought a generic parts kit from Amazon that consisted of a bunch of 3" steel pipes. This kit was about $110.
0619211124_HDR by
Paul Abbott, on Flickr
I got a 3" down pipe that I needed to weld a v-band flange on. This was $70 on eBay.
0613211108 by
0613211108_HDR by
0613211108a_HDR by
0613211157_HDR by
0613211157a_HDR by
Imagine that, its a straight pipe!
0619211931 by
For the part that goes up to the down pipe to the straight section, you just cut and weld and make it work. I didn't take any pics, but its pretty straight forward. I am not 100% on the straight pipe, but I figured it would be easy to add a muffler later if I wanted.
Back to the fuel system: After trying the intank fuel pumps, I was struggling with getting enough fuel to keep it running. I decided to just do it the old school way. So I cut up the fuel pumps and installed straight rubber hose where the pickups and returns are.
0626211318_HDR by
0626211318a_HDR by
This turned out to not work out so good so I had to pull them back out, cut up the fuel pump assembly a bit more and then secure the hoses with hose clamps. I was getting some air in the fuel system because I initially just jammed the hoses up in there. No pics. I just wanted to get it done.
While there, the fuel sending unit in the rear broke so I took a picture of how the wire goes on the front one. Well, it broke too. So I busted out the soldering iron and fixed it up.
0627211427_HDR by
I also was struggling with the idea of the switching system so I decided to just bypass the rear tank and just run clear vinyl lines from the front tank to the pump and return line. I wanted to verify that I am not getting air in the lines. I also bypassed the Ford inline fuel filter in case that was a restriction.
After a quick trip to the gas station to fill up the tank, I can confirm that my fuel system is functioning perfectly with just the lift pump doing it's thing. Finally!
Next step is an intercooler system. I am debating on just a generic eBay or Amazon intercooler setup. I am not going to be towing much of anything. Right now, cost is the most important thing. Plus I do have a pyro and boost gauge ready to be installed to keep things monitored.
Thanks for all your guys' help.
