1 - 4 of 4 Posts
Been reading about the stroker kit ACD has for the 4bt. Unless I am missing something, it appears the parts for it is just very nice looking H-beam rods and pistons. Have seen nothing about an actual stroker crank used. If I haven't missed something about a crank, how do you increase the stroke of a motor using the same crank?
Diesel World's article states factory is "4.02-inch bore with a 4.72-inch stroke" but, just by changing the pistons and rods change it to "4.402-inch and a much longer 5.430-inch stroke" without crank change. So where does the additional 0.71" of stroke come from if crank swing stays the same?
I realize that the wrist pin is moved closer to the crown of the piston, and it appears to be a change in the center to center on the rod. Which is normal for stroker motors, but it is usually required due to the increase in swing on the crank.
It's been discussed on here before and the concensus wasn't positive.
You are correct that you can't increase stroke without changing our highly modifying the crank.
1 - 4 of 4 Posts
