so I high jacked someone else's post. so I'm getting my own post going.
I'm needing a 47RH / A618... 1994 OR 1995 ..
I NEED The engine adapter & starter also. ANYONE GOT ONE.
... I have a 2000 dodge auto o/d .. I can trade ... .
.......But for my question .. I'M looking for an O/d To add onto my next project. THIS IS a Rat ROD TYPE OF A BUILD .. I have a 1989 6BT it's just the 727 trans. It's bad or not working. SO WHEN I replace it I want to swap to an O/D . I want to use toggles switches to make it shift into O'D. IF the toggle is turned off it'll not shift up into O/D .
so WHAT I'd ask . & CHAR Answered that I need a 1994 or 1995 47RH OE A618 TRANS . & I will need the engine adapter & the starter..
Question will I need the flywheel from the 95 also. or will the one from the the 89 work.
& Is there any other O/D Trans that'll work . Or might be a cheaper way out..
This rig won't see but maybe 3000K MILES A YEAR.
so Cheaper will be a big help..
............SORRY IF THIS DOESN'T MAKE Sense, without my other post.
