1 - 3 of 3 Posts
I have a question about an e350 with a 6BT swap. Van has stock dual tanks, and uses a transfer pump from front to rear tank. The rear tank feeds the FASS lift pump.
Can I hook up the stock fuel selection valve before the lift pump so I am able to select tanks rather than transfering fuel from tank to tank? would like both sending units to work as I have no way to monitor rear tank fuel level
The diesel transfer valve is different than the gas one. It has both provision for the suction and return lines so it has 6 ports. Just be sure both your tanks have the return port. Then you can use the diesel truck switching valve.
The gasser EFI dual tank transfer valve will have the required 6 ports.
Reactions: SUBRUTUS
1 - 3 of 3 Posts
