I ran a mod car in the 70's and still have two winters quick change rears. They have a 4:11 ring and pinion and use two gears in the back housing to change the final ratio. there is about 32 spur,rear gear sets to go from less than 1to1 to about 7.28 they are 3/4 ton size and you can't break them I had 500 something hp ,ran them 15 years and never hurt them,,other then crashes I have been thinking about using one of them in the ranger build, as they are lighter than a regular rear. they are magnesium and use 3/4 ton size hubs and bearings . you can put the center of the housing any where you want just with the length of the axle tube and have disc brakes, ps parts are cheep for them compaired to a regular truck rear ,and you can gear them any ratio that you want
