Dear Sir,
I have Hino K13C KT-1 engines. They are CRDi / common rail.
The engine, block, cylinders and all other specifics are same as standard Hino K13C mechanical pump engines.
Can you please advise if I can remove common rail and direct the pump with injectors as in Hino K13C mechanical pump engines.
What things to look for or need to take care in this regard.
With kind regards,
IES
With kind regards,
IES
