Here are the relevant parts from a 4BD1T manual for the fuel injection pump R&R, including bleeding system, checking the timing, and adjusting the timing.
Removal:
Replacement:
Edit: removing the power steering pump make replacement easier (end edit)
Bleeding:
Check IP Timing:
Timing the IP:
Edit: to advance timing, the top of the injection pump is rotated away from the engine, i.e. CCW looking at the IP from in front of the engine (end edit)
Some hints that I pulled from my thread on IH8MUD....Credit to longbow and doug720.
To remove if its in the truck:
- Do not need to drain oil from engine
- Used long extension with a universal to the inside IP bolts
- "I had to twist the pump out and back in from the gear sets which makes it easy to get a tooth off on reinstall." - Doug
- "Open up the little timing window cover and rotate the engine until the timing mark is dead on the pointer and then remove the pump. Try and make a witness paint mark or something on the IP drive gear location after you remove it so you can put it in the same spot when you re-install the IP so that it will be back to dead on the pointer when it is bolted back up." - longbow
- Remove the rear bracket off the IP to make re-install easier and then put the mount back on once it was positioned correctly and bolted up front.
- "Getting the pump out is tricky and takes some jockeying around to get it out of there." - longbow
Hi everybody.
Going through a few threads regarding the 4he1, can’t fine much information on any performance outcomes. I built up a compound 2.8L 4JB1T setup for my rodeo diesel drag Ute, but I am pretty close to maxed out with that setup at around 220hp and 500nm. Now currently squeezing a...
I have a 1992 4BD2T that I’ve just finished building a remote oil filter setup for that is similar to the one Doug720 designed. I need help with banjo bolts that attach the steel oil feed line to top of oil filter housing, injection pump, and pump gear cover. Two bolts have large holes and one...
I was making up an Isuzu liner removal/installer kit on request and a few extras for sale here. I have the material to make a couple of them, and this is a tool you'll probably only use once.
If I machined up a couple nice ones I was thinking about offering them for free, you pay shipping and...
