1 - 1 of 1 Posts
Vendor
Fairchild is a trusted brand in the automotive industry that manufactures rubber and plastic solutions for the repair and replacement needs of car owners. It will get you covered with everything starting from products like belt weatherstrips, door seals, cowl seals, and auxiliary seals, up to window channels, rubber seals, and weatherstrip components.
These parts are comparable to the OE factory parts and are easy to install. When you start to experience a water leak, increased road, and wind noise, or you see the loose-fitting section, weather stripping needs replacement. With Fairchild products, you can do it easily and without spending a fortune!
Fairchild Industries™ | Belt Weatherstrips, Window Channels — CARiD.com
1 - 1 of 1 Posts
