1 - 7 of 7 Posts
I am almost sure I'll be doing a semi-dry sump setup, with an oil filter relocation as well. Haven't been able to find a build on this yet, since most oil pans get modified a good bit instead.
Can I bypass the oil pickup by plumbing through the filter inlet? Or do I need to run oil pressurized through the pickup?
Not exactly sure what you're wanting to do. The filter inlet is after the oil pump and the outlet dumps back to the pan. A true dry sump system would have a belt driven oil pump that scavenges from a shallow pan and returns to a remote sump. One member has just built an aluminum pan that has an external pickup hose. It's plumbed in where the oil pan pickup would usually be. I guess that could work as long as the remote sump was lower than the pan so you'd get gravity drain back to the sump.
I want to fab a shallow pan and use an external pump. Just not sure how to feed the stock pump oil, or if the external could allow me to omit the internal pump. I guess set up a fitting going through the pan from the external pump into the internal pump is the route I'll take. Do you think the stock pump could pull from a remote sump with enough suction to scavenge the pan oil as well? I may be dreaming a bit big, and too far out of the box to use just the original pump.
Yes, what you want can be done using the internal oil pump. Look at this build and you will see an oil pan that is a work or art. In fact that whole build is worth reading. Oil pan construction starts on page 4. http://www.4btswaps.com/forum/showthread.php?40257-1972-K20-6bt/page4 You'd just need your pan so it gravity feeds to the remote sump and a pickup hose attached to the sump. This pan has a hose that draws from the pan sump but could easily be remote as well. Now, what it will cost to build is another animal.
Boothybunch - I have the 3.9 with 105 hp.
Char1355 - I have been keeping up with that post and agree it is a work of art and great craftsmanship. But I guess I missed how he was routing the oil lines and assumed there would be an external pump for that setup.
No, he's using the internal pump. Just routing the pickup outside the pan. Did that because of that notch he put in the pan for clearance. I bet he could make you a pan. Yours would be a lot less complicated without the rear sump and all those fittings. You'd just need the pickup hose fitting and a drain back fitting. The trick would be finding a location for the sump below engine level. Also, that sump would need a breather. Possibly could use a sump like the one for the hydraulic pump on a log splitter.
1 - 7 of 7 Posts
