Bought this engine many years ago for another project. Now it's going into the Wagoneer if someone can resolve the problem.
It's a 130hp P pump, stock, came out of a FrieghtLiner MT35. Replaced the injectors for a no load mid speed miss, that did not
resolve the problem. Timing is stock. I did put in the 3200 GSK.
It starts easy. After about 1/3 throttle it starts to miss and blow white smoke and flames out the exhaust.
https://flic.kr/p/2naD24w
edit:
Compression was right around 400 psi for all cylinders.
Replaced the IP overflow valve, just in case.
edit:
