sm 465 bolt behind 6bt
1 reading
4.7K views 12 replies 7 participants last post by  Paul(in NY)
#1 ·
i have a crazy ? i have a 92 cummins with the 727 auto in it. i would like to have a manual. one of the vans a bought i think has a sm465 in it. would this bolt behind my 6bt? are the bolt patterns the same from the 4bts to the 6bts?
if it did bolt up. would it hold up?
#5 ·
The weakest point is the input shaft and clutch disk when used behind a diesel. The SM-465 was a common transmission in GMC trucks that had a GVW of 21,000 pounds.
#8 ·
The SM-465 2WD & 4WD have different output shafts. From memory I recall that the 4WD had a few different adapters that connected it to the NP205 depending on the year in which it was used.
#10 ·
Transfer Case Adapter for the SM-465
I installed a transfer case adapter in my SM-465. There are several sources for adapters. I used an adapter from Novak. The adapter that I used required replacing the trans mainshaft. So, I installed a rebuild kit while I was at it.
#11 ·
Was it a 4x4 to start
and what did the adaptor cost?
#12 ·
