1 - 2 of 2 Posts
just running through the bits i need to do to convert the effer to 5 speed. the nissan box i'm using has a 16mm tip on the input shaft. the T-18 has a 17 mm tip. if i don't change the spigot, will it matter ? 0.5mm all round wouldn't do anything bad ?
Hello,
I'm assuming you are refering to the pilot bushing. 1mm clearance may not be much, but given how easy it would be to make a bushing with the right ID/OD, why take the chances?
Mikel
1 - 2 of 2 Posts
