1 - 7 of 7 Posts
· Registered
Does anyone know of a different starter that i can use. After putting my engine in and building the engine supports I built with with the starter off. My starter is leaning too much to the right and now with the motor mounted i can't install the starter. my upper control arm mount is in the way. Does anyone know of other types of starters that work with the GM Bellhousing adaptor that will put the starter closer to the block or upside down.. to get the starter away from the frame???
· Registered
I found a starter today at a local shop will post the part number at a later date it was a 3 bolt hole starter but the two that we need lined up and it turns over just fine. it alows you to have the starter sright up and down not cocked to the right. i will post more info on the starter as i find out what it came out of
1 - 7 of 7 Posts
