1 - 11 of 11 Posts
I saw no direct answer here, or in the yahoo groups, just this:
Cummins 4BT CPL858 Starter Cross References.doc
4BT Starter interchange numbers for Chevy P30 w/SM465 4 speed transmission, TH400/475 automatic, and Ford Borg Warner T-19 four speed transmission
Would these starter(s) work with the ZF-5 adapter as well, or is it going to be a completely different starter all together?
Pantherman
The transmission doesn't matter. The starter is in the adapter.
Ok, my mechanic friend wants to know what starter goes with the ZF-5 tranny adapter plate then, he wants to know if it's a OEM Ford starter that's easy to get a hold of, or if it's a Cummins OEM part.
Pantherman
have a look in the faq's. there are some threads by bobs that go into starter part no. and application. like average said, you just need the one for the ford adaptor.
I apologize then, I looked through there the 1st time and didn't find anything that related to the manual Ford tranny's.
Pantherman
The Ford adapter set that came with the Borg-Warner T19 is used with the 5 speed ZF series transmissions. Both the GM & Ford adapters sets, automatic or standard shift, use the same starters listed in the starter cross reference. This does not apply to any other adapter sets such as Dodge Cummins or any after market manufactured adapters.
If you have the small block adapter, Bobs info is correct. However if you did a b**terdized 460 pattern tranny and adapter like i did it will take some machine work that I can help you with. Let me know, Carl
PS Bob, I havnt completly forgotten you.
Discussion Starter #10
THanks, I'm pretty sure that the ZF-5 is a smallblock adapter.
Pantherman
1 - 11 of 11 Posts
