The GM SM-465 and the Borg Warner T-19 setup engine adapters both use the same starter and starter spacer. This spacer is 16 mm thick and provides the correct depth for the starter pinion and the ring gear on the flywheel to mesh properly. This same spacer is also used with the GM TH-400/475 transmission.
This spacer is Cummins part number 3906647.
