1 - 10 of 10 Posts
I have a very large Allison automatic that came from behind a 4bta in a bread truck, 2 wheel drive, anyone know which ones came on the 4bt? its a 4 speed
thanks
thanks, any easy way to tell the difference? do they use the same adapter to the engine?
Yup, they use the same `dapter. it should be an SAE#3. there`s a tag on the pass. side, rear, down near the pan flange that should tell you if it`s a 542 or 545. they look the same, biggest difference is the gear spread.:)
I may be mistaken, but I'm going on the specs I have seen, and there is no difference in the gear spread. Additionally, they have identical power ratings.
The one difference that I have been able to pin down, is that the pan depth is 5.3" on the 545, and 3.8" on the 542. I can't help but think that there must be some additional difference, but I have been unable to find it. There is a GVW rating difference between the two: 545-30,000lbs / 542-22,500lbs, that would seem to indicate some mechanical changes in addition simple fluid capacity, but I have no idea what they might be. Perhaps different numbers of clutches in the packs.
Their spec sheet shows there is an optional input retarder available with the deep pan option . I never heard of that on those models................but it was available on the 50s/70s vintage MT 40/41/42 , and Ht70 of that vintage ,plus the HT 740/750s of 70/90s vintage . In put retarders are not worth the money !
1 - 10 of 10 Posts
