Partially true today but the original EPA requirement was to prevent someone from putting leaded gasoline into an unleaded gasoline tank. This requirement was never removed by the EPA even after the sale of unleaded gasoline was no longer available at a service station.The problem I have found with using gas tanks is that most have a Fill Pipe Restrictor. Basically, the gas filler tube is to small for the diesel nozzel at the fuel station to fit into. They were made that way to make it hard to fill up your gas car with diesel...
I didn't know that. I learned about it originally from factory Ford repair manuals on my 1990 town car, from my All-Data collection. They had an entry on "Fill Pipe Restrictor".Partially true today but the original EPA requirement was to prevent someone from putting leaded gasoline into an unleaded gasoline tank. This requirement was never removed by the EPA even after the sale of unleaded gasoline was no longer available at a service station.
Some tanks can be used and some can not due to the coating on the metal but not knowing what you have .I would drop and get it cleaned because of old gas gel and the diesel will remove the gel form the bottom of the tank.I was wondering if I can use my old gas tank for my swap or do I have to use the fuel tank from my donour truck?thanks
The gas tank is plastic, and someone told me there would be problems with fuel pressure.
On Ford trucks, its as simple as changing the filler neck over from the gas style to the diesel style.
There is alot of miss-information out there about "how to make a gas fuel system work after converting it to diesel?" All you need to do on a truck that had a fuel injected gas engine setup is clean out the tank, install a delete "block off" plate where the Cummins lift pump went, install a pressure regulator inline before the Cummins injector pump. The pressure regulator will reduce the in tank pump(s) pressures to the engine, which are usually higher than a Cummins injection pump can handle. My 460 had 35psi at idle and 45psi at load, the 12 valve Cummins injection pump only likes around 15-18psi max inlet pressure. A check valve in the fuel line is also a great idea (optional). A vehicle that is old enough to have a lift (transfer) pump on the gas engine is even simpler, just hook up the lines to the Cummins lift pump.
Got a link to info on this? Or know what spring people are using?The p-pumps like pressure. The dodge guys add an extra spring to the overflow valve, will be in the 35-40 psi range at idle. Stock, its 20-25 at idle, and 35-40 at 2k rpm.
Scott, you got the right idea! If the old fuel tank is galvanized then the zinc used in the galvanizing process will react with the diesel fuel. You also want to avoid copper or any alloyed metal that contain copper or zinc, this includes fuel lines. Most earlier model gasoline fuel tanks were made of galvanized steel, later they changed to plastic tanks. If you put a coating on the inside of the tank that separates the fuel from the zinc you would probably be alright.Stainless,Plastic,Fiberglass,Black iron, and Aluminum are all OK.Some tanks can be used and some can not due to the coating on the metal but not knowing what you have .I would drop and get it cleaned because of old gas gel and the diesel will remove the gel form the bottom of the tank.
