1972 F250 4x4, 78 d60, 3.55, np205, 200hp 4bt nv4500 in progress
Having no success getting the dash gauge to function with 2 different senders. Old fe390 sender was 1/4” and block is 1/2”not.
Gauge pegs to high when grounding to the block, so it doesn’t appear to be a wiring problem. On a second 1/2” npt senders, first a GM, the second for a 1991 chevy p30 4bt van. Up to operating temp, using a temp gun, block and areas are 145-170 degrees.
sender is at front, have heater core hose at driver side rear to have better heat in winter.
These two senders are short and don’t look long like some pictures I’ve seen, wasn’t sure if they needed fully submerged or if they didn’t extend down long enough like some of the dodge 5.9l senders appear to.
