The complete Allison 1000/2000/2400 info and swap guide thread
3 reading
1M views 834 replies 142 participants last post by  cld231
#1 · (Edited by Moderator)
I decided to start a thread devoted to this trans for a couple reasons. First off, there is a LOT, and I mean a LOT of misinformation out there. Second, there is little useful info for some basic specifications on these transmissions. Finally, a lot of guys think they are too complicated or too expensive, when in fact they are no more complicated or expensive than, say, a 4L80E or 48RE that is built to do the same thing. Since I have decided to swap a 1000 into my truck I have been heavily researching all the details. While I still don't have all the answers I want, I do have most that I need, and I figured why not consolidate this information somewhere to help out other folks who contemplate this swap. I think a lot of folks get turned off of an Ally swap simply because the information is sporadic and often contradictory.
With that said, my goal for this thread is to include as much FACTUAL INFORMATION as possible. If info is prefaced by "I think", "Supposedly", "I heard", "My friend said", etc. I don't consider it factual. I don't want a thread full of anecdotal information, but rather facts that people can use to make an informed decision and help them successfully complete a swap. ;) With that said, including unconfirmed info and opinions is fine as long as it is presented as such.
Also, when adding any information, make sure to specify what generation of Allison it belongs to. There is the pre-2004 5 speed, 04-05 5 speed, and 06-up 6 speed, with various revisions among the years. Try to be as specific as possible.
Anyway, with that said I will start with some basic info about the 1000/2000/2400 series.
GENERAL INFORMATION
The Allison 1000/2000/2400 series are torque converter driven, fully automatic transmissions with 5 or 6 forward speeds. 5th and 6th are overdrive gears, and the overall ratios are dependent on model. All have a neutral and reverse gear as well, and the 1000 and 2400 series have a park position which actuates an integral park pawl. The basic max ratings for this series of transmission is 300HP, 550lb-ft input torque without SEM/torque management, 620lb-ft input torque with SEM/torque management, and 850lb-ft turbine torque. These are the ratings published by Allison for MD on-road use. As we know, the ratings for GM pickups with the DMax are higher, but the GVW and duty cycle of a pickup are less than a Md truck, so Allison rates the trans conservatively. No doubt the software in the TCM has a huge impact on the amount of power the trans can really take. GVW and GCW ratings of the trans depends mainly on whether the unit has a park pawl (units with park pawl are rated lower). GVW varies from 19,500lbs for the 1000 series to 33,000lbs for units without park. GCW ranges from 26,000lbs to 33,000lbs. Complete ratings and specs can be found here.
The gear ratios for the various models are as follows:
..........1000..........2000/2400
  • 1st.....3.10...........3.51
  • 2nd....1.81...........1.90
  • 3rd.....1.41...........1.44
  • 4th.....1.00...........1.00
  • 5th.....0.71...........0.74
  • 6th.....0.61...........0.64 (06-up models only)
  • Rev.....4.49...........5.09
INTERNAL OPERATION
Internally, the transmissions have three planetary gear sets controlled by 5 sets of clutches, labeled C1-C5. 2 clutch packs (C1-C2) are rotating, and transfer input torque to certain elements in the planetary sets, while the remaining 3 sets (c3-C5) are stationary and lock each of the ring gears and their coupled components to the case when engaged. These transmissions contain no bands, sprags, or roller clutches - all gear changes are accomplished by direct clutch-to-clutch changes. Clutch engagements for each gear are as follows:
.............C1........C2........C3........C4........C5
  • Park..........................................................*
  • Rev.........................................................
  • Neu..........................................................*
  • 1st..........................................................
  • 2nd........................................................
  • 3rd.........................................................
  • 4th.........................................................
  • 5th.........................................................
  • 6th......................................................... (06-up models only)
VALVE BODY AND TRANSMISSION ELECTRICAL
Shifting is controlled electronically. The valve body contains 6 (03-earlier) or 7 (04-up) solenoids which control all functions. Solenoids A and B are "trim" solenoids that regulate the pressure on the oncoming and off-going clutches. both are pressure proportional to current (PPC) solenoids which operate at a frequency of 1KHz. Solenoid A is normally closed, providing full line pressure at zero current and zero pressure at 100% current. Solenoid B is normally open and provides zero pressure at zero current and full line pressure at 100% current. Solenoid A controls the oncoming and applied clutches while B controls the off-going clutch. In the event of a power or TCM failure solenoid, A will default to full pressure while B defaults to zero pressure, giving a limp-home capability. 04-up valve bodies incorporate a G solenoid which reduces the main line pressure by approximately 100psi during idle and low load operation, reducing heat generation. The F solenoid controls TCC apply and release. On 05-earlier models this is a PWM solenoid operating at 100Hz, while 06-up use a PPC solenoid operating at 1KHz.
Shifting is controlled by 3 normally closed solenoids, C, D, and E. These solenoids are strictly binary, applying either full line pressure or exhaust to its associated spool valve. The logical combination of these 3 valves determines which clutches are applied. Contrary to what some believe, the solenoids do not directly operate the clutches. The spools and solenoids are arranged so that each shift change will exhaust the off-going clutch via the solenoid B path while applying pressure to the oncoming clutch via the solenoid A pressure. Because of this, shifts must be sequential - the transmission will not skip gears when upshifting or downshifting. It also means that it is not possible to apply random sets of clutches, although it is possible that the unused solenoid combinations could create a non-valid clutch condition (i.e. C2 and C5 applied) which would create a lockup. There have been anecdotes of aftermarket controllers applying all 5 clutch packs while at speed, but I don't believe it is possible to apply more than 2 clutches with the arrangement of valving in the VB. That is not confirmed, however...
Here are the solenoid combos for the various gears:
.............C...........D...........E
  • Park.............................*
  • Neu..............................*
  • 1st.....................*.............
  • 2nd.................................. (If power is lost or TCM is inoperative, this is the limp mode gear)
  • 3rd.......*..........................
  • 5th...................................*
  • 6th ???????????????????? (Don't have info for this....)
The VB also contains a pressure switch assembly which gives feedback to the TCM on which solenoids are engaged. The PSA also houses the trans temp sensor, which is a negative temperature coefficient thermistor. All VB electricals are passed through the case using a standard GM 20-pin connector, identical to the one used on the late 4l60Es and 4L80Es. Looking at the connector in the trans, starting with the upper left and working left to right, top to bottom, the pins are labeled A-W, with the letters I, O, and Q not used. The pin assignments and color codes of the INTERNAL wiring harness for 5-speed models are as follows:
  • A - Dk Green - Shift Solenoid C
  • B - Orange/Black - Shift Solenoid D
  • C - Pink - Power to shift solenoids C, D, and E
  • D - Lt Green - PSA terminal A
  • E - Red - PSA terminal C
  • F - Blue - PSa terminal B
  • G - Orange - PSA terminal E
  • H - Black - PSA terminal F
  • J - Brown - TCC solenoid F
  • K - Tan - PSA terminal D
  • L - Red/Black - Trim Solenoid A
  • M - Lt Blue - Trim Solenoid A
  • N - Gray - Trim Solenoid B
  • P - Purple - Trim Solenoid B
  • R - ????? - Line Pressure Solenoid G (04-up only)
  • S - Black - TCC Solenoid F
  • T - Tan - PSA terminal F
  • U - Green - IC to terminal V
  • V - Green - IC to terminal U
  • W - Black/Tan - Shift Solenoid E
For 6-speed models, the internal connections are as follows (no color codes - sorry:
  • A - Shift solenoid C
  • B - Shift solenoid D
  • C - Shift solenoid E
  • D - PSA terminal A
  • E - PSA terminal C
  • F - PSA terminal B
  • G - PSA terminal E
  • H - PSA terminal F, IMS terminal F
  • J - TCC solenoid F
  • K - PSA terminal D
  • L - Trim solenoid A, TCC solenoid F, main pressure solenoid G
  • M - Trim solenoid A
  • N - Trim solenoid B, shift solenoids C, D, and E
  • P - Trim solenoid B
  • R - IMS terminal A
  • S - Main pressure solenoid G
  • T - IMS terminal E
  • U - IMS terminal D
  • V - IMS terminal C
  • W - IMS terminal B
Other electrical components include 3 (05-earlier GM apps) or 2 (06-up GM apps) variable reluctance speed sensors and an NSBU (Neutral Start back-Up) switch (05-earlier) or IMS (Internal Mode Switch - 06-up). The first speed sensor is in the bell housing and gets its signal from the pump vane ribs in the converter housing. On 6-speed GM apps, the bell housing speed sensor is deleted, and the TCM instead gets engine speed information from the ECM via the GMLAN bus. The second sensor is the turbine speed sensor in the main housing, and pics up off of either the PTO gear or a stamped steel tone ring that replaces the PTO gear in units without a PTO option. Finally, 2WD transmissions have an output speed sensor in the output housing that reads off of a 40-tooth tone ring on the output shaft. 4WD models use the speed sensor and 40 tooth tone ring in the transfer case tail housing. 4WD models have a switch input to notify the TCM that 4Lo mode is engaged, and the TCM makes appropriate compensation for the TC low gear ratio.
The NSBU switch on the 01-02 5 speeds is essentially identical to that used on the 4L60Es. There are 2 receptacles on the NSBU. The 4-pin gives the TCM information regarding the gear selected, while the 7-pin accesses switches are used for P-N starter lockout and backup lights. The 4-pin receptacle's pins are marked A, B, C, and D. Depending on the shift position selected, a combination of 2 of these pins will be grounded. Here's the table, with the grounded pins marked with an asterisk:
.............A...........B...........C.........D
  • P.................................................
  • R................................................
  • N...............................................
  • D................................................
  • 3...................................................
  • 2................................................
  • 1...............................................
Since only 2 terminals or no terminals (in the case of 3rd) are valid combinations, the TCM can sometimes determine if there is a wiring or switch malfunction. The standard wiring color codes and their connection to the TCM J2 connector for the 4-pin receptacle are as follows:
  • A - Blue - pin 5
  • B - Gray - pin 7
  • C - White - pin 8
  • D - Yellow - pin 6
NOTE: On GM pickups, these wires go to the ECM, which then buffers and feeds them to the TCM. On stand-alone apps, they will be wired directly to the TCM. This is a helpful bit of info for those modding a GM pickup harness ;)
The 7-pin connector on the NSBU has pins labeled A-G, and their corresponding wire colors and assignments are as follows:
  • A - Not used
  • B - Tan - Park Accessory
  • C - Blue - Rev/Park Accessory fuse
  • D - Green - TCM analog ground (TCM J2 connector, pin 20)
  • E - Yellow - Park/neutral start battery feed
  • F - Pink - backup lamps
  • G - Orange - Starter relay
03-05 models used a very similar NSBU switch assembly, except they have a single connector that contains all the pins, rather than 2 separate connectors.
06-up 6-speed transmissions no longer use an external NSBU switch. The external switches were prone to failure caused by internal corrosion due to exposure to water. The park and reverse accessory and backup lamp switch functions were moved to the column. Park/neutral and gear selector position info on these transmissions is done with an internal mode switch (IMS) mounted on the rooster comb inside the transmission. Its functions are brought out through the 20-pin connector on the transmission (see above). The F pin on the IMS is common, and depending on position one or more of the remaining pins will be switched to the F pin. Pin A is connected to the ECM, and is used to notify it that the transmission is in either park or neutral, thus allowing the engine to be cranked. The final 4 (B-E) are connected directly to the TCM and tell it what range is selected, NOTE; On GM trucks, the PRNDL is labeled P-R-N-D-M-1, with only those 6 positions available via the column shifter. However, the transmission itself has 7 positions internally - the last position is simply not used in GM vehicles, and the travel is limited in the column shifter so a GM vehicle cannot physically shift into the last position. However, a DIY shifter setup WILL be able to shift into that last position unless it is likewise limited (i.e. using a 3-speed floor shifter rather than a 4-speed floor shifter).
Note that these pin assignments are those of the switch itself, NOT the 20-pin external connector. Refer to the external pinout description above for the 6-speed to find the external pins connected to these internal pins.
............A............B............C............D............E
  • P....................................*.............................
  • R..................................................................
  • N.................................................*...............
  • D..................................................................
  • 3...............................................................
  • 2..................................................................
  • 1..................................................................
Information continued in later posts.
#790 ·
LOTS of good info here. i am starting a new project that includes a lot of this subject matter. i am trying to figure it out for what i need. here is the deal. i have a 1973 chevy suburban that i use for towing a stacker trailer. i dont like the gas 454 engine, not enough torque for me. the trailer weighs close to 10k loaded. i bought a 2003 e350 ford conversion van that was a rollover and removed the entire 7.3l ford engine and harnesses. i bought a sae trans adapter out of a 1995 t444e international that bolts to the ford engine. i had a allison 545 trans on it, but it doesnt have the od i need. the rear end is a rockwell with 5.29 gears, and the engine will rev too much with the diesel. i bought a allison 1000 out of a 2006 chevy silverado with a complete harness and tcm,bcm,ip cluster,steering column, etc so i am trying to hook up the original dash lights for trans lights, and get the tow button and tap shift to work. i am getting wiring diagrams finalised for all of this. i know this is a lot, but am willing to figure it out using the stock components. anybody that might have some input on what will be the hard parts to get working feel free to comment.
#794 ·
It could be the torque converter, not the trans. Any codes?
#797 ·
Hey guys, so been reading this for a few days now. I hope I can be pointed out in the right direction.
I have a 97gmc t6500. It has a 2001 cat engine and had a eaton 6 speed.
I have installed a allison 2500 rds and from what I understand it is a 5 speed. Date is 05E24.
So I have the cooler driveshaft and everything set up.
I am at the wiring harness. Which I did receive a harness and tcm with it. Can anyone give me what wire I need to connect on what pin on the ecu side from the tcm?
Will I have to put risisters for data link? I do not think I have j1939 connection. But you can correct me if I am wrong.
If it is possible to be told what wires I need from ecu to pcm with the pins. I dont want to mess that up and I am on a time crunch.
And if I do need resisters.. where can I get those?
Thank you so much and my apologies if this is alot to ask.
Great thread tho. I know it was mostly aimed at 6 speed conversion but title does mention most allison trans. Thank you again.
I can attach pictures of the harness if need be.
#799 ·
GENERAL INFORMATION
INTERNAL OPERATION
Shifting is controlled electronically. The valve body contains 6 (03-earlier) or 7 (04-up) solenoids which control all functions. Solenoids A and B are "trim" solenoids which regulate the pressure to the on coming and off going clutches. both are pressure proportional to current (PPC) solenoids which operate at a frequency of 1KHz. Solenoid A is normally closed, providing full line pressure at zero current and zero pressure at 100% current. Solenoid B is normally open, and provides zero pressure at zero current and full line pressure at 100% current. Solenoid A controls the oncoming and applied clutches while B controls the offgoing clutch. In the event of power or TCM failure solenoid A will default to full pressure while B defaults to zero pressure, giving a limp-home capability. 04-up valve bodies incorporate a G solenoid which reduces the main line pressure by approximately 100psi during idle and low load operation, reducing heat generation. The F solenoid controls TCC apply and release. On 05-earlier models this is a PWM solenoid operating at 100Hz, while 06-up use a PPC solenoid operating at 1KHz.
Shifting is contrilled by 3 normally closed solenoids, C,D, and E. These solenoids are strictly binary, applying either full line pressure or exhaust to it's associated spool valve. The logical combination of these 3 valves determines which clutches are applied. Contrary to what some believe, the solenoids do not directly operate the clutches. The spools and solenoids are arranged so that each shift change will exhaust the offgoing clutch via the solenoid B path while applying pressure to the oncoming clutch via the solenoid A pressure. Because of this, shifts must be sequential - the transmission will not skip gears when upshifting or downshifting. It also means that it is not possible to apply random sets of clutches, although it is possible that the unused solenoid combinations could create a non-valid clutch condition (i.e. C2 and C5 applied) which would create a lockup. There has been anecdotes of aftermarket controllers applying all 5 clutch packs while at speed, but I don't believe it is possible to apply more than 2 clutches with the arrangement of valving in the VB. That is not confirmed however...
The VB also contains a pressure switch assembly which gives feedback to the TCM on which solenoids are engaged. The PSA also houses the trans temp sensor, which is a negative temperature coefficient thermistor. All VB electricals are passed through the case using a standard GM 20 pin connector, identical to the one used on the late 4l60E's and 4L80E's. Looking at the connector in the trans, starting with the upper left and working left to right, top to bottom, the pins are labeled A-W, with the letters I, O, and Q not used. The pin assignments and color codes of the INTERNAL wiring harness for 5 speed models are as follows:
For 6 speed models, the internal connections are as follows (no color codes - sorry:
D - PSA terminal A
E - PSA terminal C
F - PSA terminal B
G - PSA terminal E
J - TCC solenoid F
K - PSA terminal D
M - Trim solenoid A
P - Trim solenoid B
R - IMS terminal A
T - IMS terminal E
U - IMS terminal D
V - IMS terminal C
W - IMS terminal B
Other electrical components include 3 (05-earlier GM apps) or 2 (06-up GM apps) variable reluctance speed sensors and an NSBU (Neutral Start back-Up) switch (05-earlier) or IMS (Internal Mode Switch - 06-up). The first speed sensor is in the bellhousing, and gets it's signal from the pump vane ribs in the converter housing. On 6 speed GM apps, the bellhousing speed sensor is deleted, and the TCM instead gets engine speed information from the ECM via the GMLAN bus. The second sensor is the turbine speed sensor in the main housing, and pics up off of either the PTO gear or a stamped steel tone ring that replaces the PTO gear in units without a PTO option. Finally, 2WD transmissions have an output speed sensor in the output housing that reads off of a 40 tooth tone ring on the output shaft. 4WD models use the speed sensor and 40 tooth tone ring in the transfer case tailhousing. 4WD models have a switch input to notify the TCM that 4Lo mode is engaged, and the TCM makes appropriate compensation for the TC low gear ratio.
The NSBU switch on the 01-02 5 speeds is essentially identical to that used on the 4L60E's. There are 2 receptacles on the NSBU. The 4 pin gives the TCM information regarding the gear selected, while the 7 pin accesses switches used for P-N starter lockout and back-up lights. The 4 pin receptacle's pins are marked A, B, C, and D. Depending on the shift position selected, a combination of 2 of these pins will be grounded. Here's the table, with the grounded pins marked with an asterisk:
Since only 2 terminals or no terminals (in the case of 3rd) are valid combinations, the TCM can sometimes determine if there is a wiring or switch malfunction. The standard wiring color codes and their connection to the TCM J2 connector for the 4 pin receptacle are as follows:
A - Blue - pin 5
B - Gray - pin 7
C - White - pin 8
D - Yellow - pin 6
The 7 pin connector on the NSBU has pins labeled A-G, and their corresponding wire colors and assignments are as follows:
A - Not used
F - Pink - back-up lamps
06-up 6 speed transmissions no longer use an external NSBU switch. The external switches were prone to failure caused by internal corrosion due to exposure to water. The park and reverse accessory and back up lamp switch functions were moved to the column. Park/neutral and gear selector position info on these transmissions is done with an internal mode switch (IMS) mounted on the rooster comb inside the transmission. Its functions are brought out through the 20 pin connector on the transmission (see above). The F pin on the IMS is common, and depending on position one or more of the remaining pins will be switched to the F pin. Pin A is connected to the ECM, and is used to notify it that the transmission is in either park or neutral, thus allowing the engine to be cranked. The final 4 (B-E) are connected directly to the TCM and tell it what range is selected, NOTE; On GM trucks, the PRNDL is labeled P-R-N-D-M-1, with only those 6 positions available via the column shifter. However, the transmission itself has 7 positions internally - the last position is simply not used in GM vehicles, and the travel is limited in the column shifter so a GM vehicle cannot physically shift into the last position. However, a DIY shifter setup WILL be able to shift into that last position unless it is likewise limited (i.e. using a 3 speed floor shifter rather than a 4 speed floor shifter).
Note that these pin assignments are those of the switch itself, NOT the 20 pin external connector. Refer to the external pinout description above for the 6 speed to find the external pins connected to these internal pins.
Hey I know this about your Blazer! Did you modify the core support to fit the inner cooler? Thanks for your time! Dave
#800 ·
This is a little off topic and backwards but here goes.
I'm installing a Cummins ISB170 in front of a ZF8HP trans. I was hoping to use some sort of torque management but cant find any info on what sort of signals the ISB wants to see from the trans so I'm wondering what the Allison sends to the ISB?
#802 ·
Yes, I did see that on the wiring info but on the stock wiring between my 5 speed MD Allison and ISB there is just the shielded J1939 which leads me to believe that its done via CAN.
There are no wires in locations 36 and 40 on my ECM.
#804 ·
Hi Guys,
Been lurking in this thread for a while.
Have read thru all 41 pages multiple times.
I'm brain fried.
Making a wiring harness scares me and can't seem to make sense of what TCM I should buy.
If I'm posting in the wrong thread apologies in advance.
My project is to put an '06 Allison 6 speed in a 1989 Coachman Catalina Motorhome. Currently has a Carb'ed 454 gas motor. i.e. no electronics & a THM400 tranny. Am looking to buy a wiring harness & a Allison MD TCM that will accept an analog TPS input. Or somebody that can re-flash an Allison MD TCM to those specs & tell me what TCM I should buy from a local salvage yard.
I'm a retired Navy Submarine ET living on a fixed income so while I have some money I'm not a rich guy.
I'm electronically competent & digital savy with strong mechanical skills.
I have access to a competent driveline shop who can cut & balance a drive shaft.
The 454 has headers (smog deleted) & will upgrade to EFI (prolly the Holley system).
Would like to have the Allison tap shift so I can lock it out of 5th or 6th cuz' i don't think the 454 will pull a hill in overdrive.
Intention is to use a rocker switch on the dashboard for gear selection when in "M", else operate in "D" w/ shift points suitable to a gas motor limited to ~4500 RPM (when on flat roads).
Any help or a pointer to an affordable dealer/seller would be much appreciated.
Thanks in advance & PM's are solicited & desirable.
BTW, I have a '05 4WD 5 speed Allison & torque converter & a A40 TCM which came out of a '05 GMC Duramax which I bought as a spares for my '05 which I'm willing to sell. Will post pic's if desired.
#806 ·
Thanks for the post, wasn't sure this thread was still active.
I'm in Jason's build queue & I WILL buy a TCM & harness from him because:
1) He is, hands down, the most knowledgeable, most open w/ information, & most ethical individual/company I've talked to to date. A real class act.
2) His labor rates & pricing are very affordable & prolly too low for the market given the service/quality rendered.
3) I need a stable functional transmission that is as close to "plug 'n' play" as is possible.
My issue(s) is/are:
1) I'm an old fart whose physical capabilities are failing,
2) I live in Northern MN & have concerns about surviving another -50F winter (frost bite 2 years running & almost lost my left foot last winter, diabetes sucks).,
3) I don't have a tall door/ceiling shop to do the work in,
3) At the risk of releasing too much personal info, he's recovering from COVID,
4) He's overworked & backlogged till Sept.,
5) The MH was built & geared in the era of the 55 mph National speed limit so the 454 is screaming @ 60 mph & at 70 is way above it's peak torque curve. @ 80 mph (the unofficial speed limit in the right hand lane on Hwy 29) it sounds like it's gonna' throw pistons out the side.
6) Motor swap in a puller MH will be a B.....
7) Towing on a MH isn't just expensive it's F'ing expensive.
i.e. I have a limited time window to do the swap or be condemned to staying off the National Hwy system.
I may have to temporarily, for this winter run south, swap in a 700R4 w/ lock up & baby it (BIG cooler & watch tranny temps).
Was hoping for an affordable temporary Allison 6 speed solution while Jason catches up on his work backlog.
Like maybe somebody started a Jason conversion & for whatever reason gave up on it & has parts for sale (wiring harness &/or Allison MD TCM). This option would simplify Jason's workload, get me on the road sooner, & free up $$$ for the seller at what he/she paid for it.
BTW, his advice/document on TPS's was immensely helpful. And after a little pricing research, it resulted in an optimal ease of installation solution @ the lowest cost. The TCM6000 - Remote Mount TPS Adapter Kit (A-TCM6000) from Pace Performance @ $100.80 + $13.32 (shipping) = $114.12 delivered to my door. Sweet.
Also looking for a EFI Live Flashscan or Autocal V2 as it seems EFI Live screwed up the V3.
Be safe folks & thanks for the response.
#812 ·
That's actually post #95. Took me a while rummaging through my HD to find that one. It's fixed now.
#816 ·
The splines are metric. 1.25 module, 30° PA, involute splines.
#818 ·
I didn't see the answer to my question in this thread. I am building a custom spud shaft and need to know if the short 2wd Allison output shaft is 29 spline and will mate up to my 241 29 spline input.
The 2WD shaft is 35 spline, IIRC. It is also retained by an end bolt through the yoke. And it has a tail housing that is particular to 2WD.
You need the 29 spline 4WD output shaft. It has fine threads between the t-case splines and the roller bearing surface. You also need the spanner nut that fits those threads. Finally, you need the 4WD extension housing. Make sure you get the 2006-2010 6 speed housing. The earlier housings will work fine, but theyre not as strong. The 2011-later housings have a completely different t-case mounting face, and would require a custom adapter plate to accept a standard round pattern transfer case. Check end play - specs are in the ATSG manual.
If youre using a GM transfer case, whether driver or passenger drop, with a 29 spline Dodge input shaft it will bolt right up to the Allison. The Dodge has a different bolt pattern and will require re-drilling the face of the Allison extension housing to match. Given a choice, Id rather swap a 29 spline input into a GM case.
#820 ·
Hopefully I can figure this out eventually, but its been a mind boggling experience getting my allison to work with my throttle controller. I programed a PIC to take a 0-5V analog signal and send a PWM output on 2 different pins.
I planned sending it to the unmanaged and managed pins on the TCM (01 8.1), but it just will not shift correctly. I now notice that with key on, I am getting voltage coming FROM the tcm on those pins. One has 5v and the other 12v going from the TCM INTO my controller. I have no clue what is going on now. Do I just have a junk TCM that has had me on a wild goose chase for the last 2 years?
#821 ·
First, confirm that you are indeed using inputs. If so, then it's most likely those inputs have pull-ups on them. That seems to be common on automotive stuff. They are designed tp be connected to an open drain/open collector output. Rather than driving a TTL level signal out of your PIC, connect the gate of a small N-channel MOSFET or base of an NPN bipolar transistor to the output of your PIC. Use a suitable resistor in series with the gate or base. 10 ohm is fine for a gate snubber. Fof the base, it depends on the beta of the transistor. Also, use a 10K pullup resistor at the junction of the gate/base resistor ad PIC output to prevent floating on power-up before the pin is initialized. The source/emitter goes to ground, and the drain/collector goes to the input on the TCM. Now, keep in mind that the result is an inverter, so that a HIGH output on the PIC results in a LOW input into the TCM and vice-versa. So, you will need to digitally invert your signal going out. Otherwise, your PWM signal will be backwards.
FWIW, I haven't used a PIC since I left Microchip over 20 years ago. You may want to check the data sheet and see if it's possible to configure the output pin to an open drain. If so, then you need not bother with the external transistors and resistors. Alternatively, there are chips out there that accept a TTL-level input (with or without a Schmitt trigger) and give an open drain or open collector output. They are often used for LED or lamp drivers and such. These are easier to use than discrete components, and would probably be your best bet. There may even be some with inverting inputs, so the output would pull low when the input is low. That would eliminate the need to invert the logic in the software, even though that is trivial to do.
#822 ·
I used the 8.1 set up for a few gas powered trucks several years ago because the RPM range was higher. I no longer need it for gas powered applications because I can edit ALL the RPM ranges for what I typically offer (they are not all defined in EFI Live). I haven't supported the 8.1 system in years and won't be in the future so I will help out a bit this one time for those guys that want to try it. It may work fine for some guys that have fairly stock engines and aren't too picky, even though being picky about things is not a bad thing.
I tried to attach a full flash A40 8.1 calibration that you can use to reflash an A40 Duramax TCM with EFI Live, and a program for a 5150v5 Velocio PLC that converts an analog tps signal to the PWM managed and unmanaged torque signals here but it's not allowed. I have them available on my forum here. If someone wants to manage them elsewhere that's fine and the moderator can delete this post. The Velocio PLC makes a little better signal than the CAT PWM TPS, but it still limits the max TP% out to 69%. It also has code to control a reverse light relay, using two shared signals from the IMS sensor.
I will not respond to messages or posts here so please don't try that, and will not help with custom tuning the 8.1 calibration - sorry, too busy for that these days. Have at it on your own or with help from other guys on this thread using the 8.1 system, I'm confident they can fill in the holes for others that can't. A tip of my hat to you Max.
#823 ·
I appreciate your input and the links! I also agree with your assessment of the 8.1 system. It was intended as a simple, relatively easy and low cost way from point A to B without going full CAN. I long ago moved on to using a CAN-based system so I can run a DMax OS, and specifically so I can use the 11-up transmissions with variable line pressure. The 8.1L OS never supported the 11-up valve bodies, as you are aware. I also have ways of supporting torque management on a mechanical engine, which allows the transmission to be used on engines making torque figures similar to a stock 2018 Duramax. Of course, with a built trans and proper tuning it is possible for the trans to function reliably behind a 1000+lb-ft 12V. Having twin CAN busses is nice as it allows GM-LAN on one to talk to the Allison TCM and J-1939 on the other to talk to a Holset VGT actuator. Or, the GM-LAN can talk to the Allison TCM while the J-1939 listens to the Cummins ECM and translates relevant messages back and forth.
Unfortunately, like you I don't have the time to help people out with any Allison swap stuff. I do still try to answer basic questions on this thread, but thats about it. I haven't done anything Allison-related in quite some time. Aside from my own projects, I leave it to other people who have time (and a business) to devote to it.
Again, thank you for your input and links.
Reactions: Russ McLean
#825 ·
This thread has been an amazing read, and as helped motivate me to do my own Allison swap behind my 7.3L.
I'm going the SAE bellhousing route which means sourcing one from a salvage yard (or Ebay in this case). Wondering if anyone here knows what to look out for with regards to the condition of these? Mine has some scratches and damage where the oil pump o-ring sits, but don't know if it's enough to effect operation
#826 · (Edited)
Lightly sand the defects to make sure there are no high spots. Don't overdo it and end up with a low spot! It should be ok.
FWIW, you can get new ones at an Alision dealer, if the used ones don't work out.
#828 ·
Anyone have a pin out for the 10 pin connector about 6 inches away from the grey TCM connector on a 2004 MD 5 speed 1000 from a freightliner mt45? There are 4 grey or white wires that go to the TCM ( pins 2, 3, 4, 13 and 28 } and 5 wires that go to the NSBU (maybe)
Swapped a MD 5.9/1000 into a 2004 International 4700 that had a T444e/545 and that is the last bit of wiring to finish up.
#832 ·
I analyzed the 2wd output shaft on a 2500pts (2wd) with a date code of 08c26, SN 6310864176 and it's approximately 0.9% Chromium and Manganese, with the balance Iron. This works out to a 51xx alloy. This is not surprising as 51xx is a middle of the road economical alloy common in the automotive industry for shafts and gears and such. The issue with the other alloys is molybdenum is about 100 times more expensive than iron, so for every one percent Mo, it doubles the cost of the steel. Nickel is about 10-20x iron, Chromium is 5-10x, and Manganese is 2-3x the cost of iron. From the manufacture's perspective, it's cheaper to spec a larger diameter shaft with a cheaper alloy than it is a smaller one with a more premium alloy, while still maintaining the required specs. Particular on units like these where weight is not the primary design criteria.
All this is to say is the carbon content is still unknown as 5120 seems to be about as common as 5130 and 5140, but I am by no means an expert on this. But from my perspective, given the size of the output shaft, I think you're going to break something else first-like the planetary gears. But everything about the Allison 1000/2000 series is crazy beefy compared to a 4l80e or a 48re, and people build these other units to handle ridiculous power. So it seems to me if you mod the transmission so the clutches can hold the power, you should be ok for quite a bit more power. Also, these transmissions aren't exactly outrageously expensive from the scrap yard, so you ought to be able to find a replacement unit for about the cost of a billet output shaft should you have the unfortunate experience of discovering where the upper limit lies.
